QtJSAPI usage
Discussion forum for C++ and script developers who are using the QCAD development platform or who are looking to contribute to QCAD (translations, documentation, etc).
Attach drawing files, scripts and screenshots.
QtJSAPI usage
Post by andrew » Mon Nov 13, 2023 10:45 am
From a developer:
Can I expose an already existing QMainWindow and access all its children from a .js script?
Re: QtJSAPI usage
Post by andrew » Mon Nov 13, 2023 10:54 am
Yes. You can expose existing QObject objects as you normally would:
QJSEngine* engine = new QJSEngine();
RJSApi* rjsapi = new RJSApi(engine);
// this makes the Qt classes known to the script engine:
rjsapi->init();
QJSValue global = engine->globalObject();
global.setProperty("appWin", engine->newQObject(appWin));
QQmlEngine::setObjectOwnership(appWin, QQmlEngine::CppOwnership);
In JS, you can then use:
var w = appWin.findChild('NameOfChild');
or for example:
var children = appWin.children();
Return to “QCAD Programming, Script Programming and Contributing”
