ecma script attribute.setInvisible() is not hidding the attribute
ssm2017
Post by ssm2017 » Sat Nov 25, 2023 8:44 pm
hello,
using :
Version:
3.28.2.0 (3.28.2)
using ecma script in the script shell.
i get a block attribute in a var called attribute.
i can use : attribute.getTag() or attribute.getPlainText() without issue.
i am not able to hide this attribute using : attribute.setInvisible(true)
the method attribute.isInvisible() is answering true or false but the attribute is not hidden on the drawing.
is it a bug or a wrong use ?
Re: ecma script attribute.setInvisible() is not hidding the attribute
Post by CVH » Sat Nov 25, 2023 10:35 pm
You queried an entity from the document, regard it as a clone, and altered some properties.
The properties of the document entity are not affected.
You need to recast that entity back to the document.
ssm2017
Post by ssm2017 » Sat Nov 25, 2023 10:59 pm
do you have any example on how to do it please ?
Post by CVH » Sat Nov 25, 2023 11:12 pm
You might want to search the forums on the term "RModifyObjectsOperation" for code snippets.
I would step away from the Script Shell at some point and implement Addons.
All QCAD tools are implemented as Addons in ECMAScript, for open source see:
https://github.com/qcad/qcad/tree/master/scripts
Full class descriptions:
https://qcad.org/doc/qcad/3.0/developer/modules.html
