Possibly one for Andrew.
I've only just noticed that if I set the tab font to italic in a stylesheet, the font displays correctly in horizontal tabs but is ignored in vertical tabs. Setting the font to bold displays correctly in both horizontal and vertical tabs.
Might this be a limitation with vertically aligned text ??
[SOLVED] Font display in vertical tabs.
- petevick
Pete Vickerstaff
- petevick
Re: Font display in vertical tabs.
On closer inspection, it's not that vertical tabs do not display italics, it's that they don't display italics correctly, the text is slightly distorted as shown in this enlarged screenshot.......
Pete Vickerstaff
- petevick
this is a Qt bug that cannot be fixed in QCAD
https://ribbonsoft.com/bugtracker/index ... omment3233
Pete Vickerstaff
