RPolyline.reverse() apparently only returns the bool value of true. What is the intent of this method?
Does a method exist for RPolyline which will reverse the direction of the polyline, reverse the order of the vertices?
I want to reverse a polyline then appendVertex() or appendShape() to the original startPoint of the polyline. I have polylines that I am attempting to aggregate that were drawn with different orientations, clockwise or counter-clockwise with respect to the closed outline I am attempting to create from them.
reversing polylines
- Junior Member
Re: reversing polylines
Yes, reverse is the method you are looking for. Perhaps, you can provide a bit of context (code), so we can help efficiently.
You also might want to have a look at this code of the Modify > Reverse tool of QCAD which also works for polylines:
https://github.com/qcad/qcad/blob/maste ... Reverse.js
With an RPolyline shape in a variable called 'poly'
poly.reverse(); will reverse the orientation of the RPolyline stored in 'poly'.
That is all there is to it.
Also see:
https://qcad.org/doc/qcad/3.0/developer ... 14d08a32ef
var test = poly.reverse(); will indeed return a boolean in 'test' and also reverse the orientation of the shape in 'poly'.
You really don't need the var test = part.
The boolean is always true, see: https://github.com/qcad/qcad/blob/maste ... 1938-L1967
Line 1966 simply returns true.
Also see:
