[Solved] DWG to DXF format
yamyam
Post by yamyam » Fri Apr 19, 2024 2:46 am
WIN10 + QCAD 3.29.6.3
Hello, everyone
I am converting DWG format to DWG format using C++. After trying many third-party libraries, I found that QCAD has the best compatibility.
May I ask where is the module or library for parsing and converting DWG format in the QCAD source code? Or how to use C++ to convert DWG to DXF format through other methods.
Thank you so much
Re: DWG to DXF format
Post by CVH » Fri Apr 19, 2024 5:26 am
It is not really a C++ library ...
You can do that with QCAD Professional using a Command Line tool:
https://www.ribbonsoft.com/en/products/ ... _/_pdf2dwg
You would have to call an external process.
yamyam
Post by yamyam » Fri Apr 19, 2024 7:21 am
Thanks a lot!
