ECMAScript reference to the current QCAD document
michal_w
Post by michal_w » Mon Feb 10, 2025 10:14 am
Would you please tell me how to get the reference to the active (open) QCAD document?
Thank you
Michał
Re: ECMAScript reference to the current QCAD document
Post by CVH » Mon Feb 10, 2025 11:24 am
Depends on where it is required.
When eventually based on EAction then it can be as simple as this.getDocument();
Then basically the same as EAction.getDocument();
With a known RDocumentInterface in di again very simple: di.getDocument();
There are countless methods.
Try to enter the search term 'getDocument' in the QCAD reference
michal_w
Post by michal_w » Mon Feb 10, 2025 7:53 pm
Thank you for your hints.
Michał
