Block using other block refrences as components?
bambuko
Senior Member
Post by bambuko » Tue Apr 09, 2024 9:28 am
as per title, (or "can I insert block into a block")
any reason why I shouldn't do it?
I must admit to experiencing some confusing behaviours when doing it...
QCAD Professional
Version: 3.28.2.0 (3.28.2)
Internet: QCAD.org
Build Date: Aug 30 2023
Revision: a8039fc
Qt Version: 5.8.0
Architecture: x86_64
Compiler: gcc 4.8.1
QCad Pro
Linux MX-21.3 "Wildflower"
Re: Block using other block refrences as components?
Post by CVH » Tue Apr 09, 2024 11:34 am
Stacked Block References should be OK.
The Attributes like Color, Lineweight, Linetype, visibility are inherited from parents depending several settings and some Preferences.
Your attributes can be By Layer, By Block or custom specified.
Application Layer compatibility has an influence on Block entities on Layer 0.
https://www.ribbonsoft.com/en/tutorial- ... ith-layers
https://www.ribbonsoft.com/en/tutorial- ... attributes
The only thing to avoid in QCAD are so called 'Massive Blocks' as they tend to reduce rendering speed.
bambuko
Senior Member
Post by bambuko » Tue Apr 09, 2024 1:12 pm
thanks,
the problem I had was with layers not behaving the way I expected...
probably just me (as usual :mrgreen: )
QCad Pro
