Control Over Dimensions
Posted: Sat Feb 15, 2025 4:28 am
				Hi All,
I haven't come across this before because I usually supply files for profile/laser cutting without dimensions and provide PDFs with dimensions when required. However, a customer requested the dimensioned DXF, and this is how it opened in AutoCAD.
Is there a way to control the "Dim Line Color"? Also, the diameter and radius symbols show twice when I add the prefix. Is there a way to fix that?
This is how it displays in Qcad: This is how it displays in AutoDesk True View: This is how it displays in Acad: Here are the "Dim line color" Properties: Thanks for any help in advance..
Cheers
John
PS Adding dxf file for reference ...
Cheers
John
 , but it is good to know that this workaround is required when the receiver uses ACAD.
