Cut & Copy Fails to function
mlwoy
Post by mlwoy » Wed Jul 30, 2025 5:24 pm
Operating System: Mac OS ver: Sequoia 15.5
Qcad Ver: 3.31.1
All of a sudden the Copy- Paste and Cut and Paste have stopped working.
Odd, I must say.
Highlight the item or line to be moved or copied using the mouse, All lines are highlighted, Use "Command C", Text shows "Command: Copy.
Enter command from Keyboard "Command V" Text shows "Command:Paste. 'Command Line shows Position:, however when moving the mouse the silhouette of the item does not move with the mouse, nothing happens.
This also happens when the commands are picked from the Edit menu as well.
Now the Move command does work from the Modify menu.
Have tried closing down the software, rebooting the computer, and opening a new document, nothing seems to effect it.
Never had this happen all the fifteen years I have been using the software.
Martin Woy
Re: Cut & Copy Fails to function
Post by Husky » Wed Jul 30, 2025 7:52 pm
Check active layer status: Frozen or locked?
Check copy/paste options: ... to active layer?
