Flip parameter
ionut
Flip parameter
Post by ionut » Tue Oct 14, 2025 7:49 am
Starting from QCAD pro dxf files with extra xData I've started building a 3D BIM modeler.
https://www.youtube.com/watch?v=pDnM-um ... a7p4AaABAg
To handle the 2D to 3D conversion from blocks to windows, doors or other complex geometry, I was thinking to introduce a "flip" parameter.
My question here is - is there any interactiv function in QCAD pro that can help me do this?
Static is not a problem.
Re: Flip parameter
Post by CVH » Tue Oct 14, 2025 9:09 am
Blocks or Block definitions have no 'Flip' property.
A Block listed in the Block List is not a standalone drawing entity, it is rather a named container for grouping drawing entities.
A Block Reference is itself a drawing entity that displays a virtual copy of the Block content at a position, in a certain scale, rotation and so on.
Flipping a Block Reference can be nothing more than a negative scale in X and/or Y.
In fact, it is displayed mirrored in regards with the X and/or Y axis of the Block definition.
But flipping may also be in regards with the center of the bounding box.
For a selected Block Reference or any selection of entities: Modify .. Flip Horizontal (FH) or Vertical (FV).
Expect a rotation change when flipping a Block Reference.
FH and FV could be simplified to a negative scale when the Block origin is centered.
scripts/Modify/FlipHorizontal/FlipHorizontal.js and scripts/Modify/FlipVertical/FlipVertical.js
Of those scripts the beginEvent must be triggered with an existing selection.
By default one is editing the Model_Space Block.
For flipping all the content of a Block definition you need to edit the intended Block and Select All (TA).
Selected or not is a volatile entity status when QCAD is running and not a drawing entity status saved to DXF.
Perhaps this all can be achieved with a set of dedicated ECMAScript's that make the bridge between a Phyton call and the QCAD API.
Similar as calling the QCAD Revert method combined with reading command line arguments.
On the other hand ...
Figuring out a bounding box and/or mirroring an entity in regards with an axis is far less complex than what you achieved already.
Impressing stuff :!:
ionut
Re: Flip parameter
Post by ionut » Tue Oct 14, 2025 10:40 am
Interesting - the negative scale x/y works perfect for me!
Thank you!
I am working now on a demo video for a 11 storey/ 44 apartments demo - from qcad draft to 3D glb and IFC model.
There are still some functions that will make this app verry user friendly for QCAD pro users - but I will come back with questions.
I don't want to do reinvent the wheel if there are already functions that work in QCAD done by smarter people than me!
Thank you again!
