Drawing scale on layout block
crstn
Post by crstn » Fri Nov 14, 2025 1:47 pm
Hi
I am new to QCad so please bear with me ...
I haved searched a lot for an answer to my question, so maybe the question is wrong, but:
I have made a relatively simple floor plan, and I want to print it via a viewport in a layout block.
What I can't figure out is how to read/find the scale of my drawing as it is shown on my sheet of A4 paper.
In the properties of the viewport it has a scale of '0.97', which is certainly not the scale of my 9,44 m wide building shown on a 210 mm wide piece of paper ...
When printing directly from the model space I can scale the drawing to 1:67, which makes sense, but where do I find/set that scale when printing via a layout block?
Any advice is much appreciated!
Re: Drawing scale on layout block
Post by CVH » Fri Nov 14, 2025 2:32 pm
If one edits a Paper_Space block or Layout then QCAD turns on the print preview mode.
Each Layout Block has its own specific paper scale that may differ from a simple print preview of Model_Space.
Essentially the parameters of the Layout 'Model' and stored in the global Drawing Preferences
Before there was a scale field in the Options Toolbar when viewing a Layout Block.
In recent QCAD releases one can change the paper scale by clicking on the 'Page Settings' button.
While creating a Viewport one can set the scale before defining the second corner.
The scale of a selected Viewport can be altered using the Property Editor.
I would not scale the content of my Viewport but use a paper scale for everything in the same scale on paper.
But you can of course add a Viewport of some details in another scale.
Post by andrew » Fri Nov 14, 2025 2:51 pm
When using layout blocks, the paper scale mentioned above should always be 1 or 1:1 (default). I.e. whatever you draw into the layout block directly (drawing border, drawing header, etc.) is drawn 1:1.
Individual viewports can be scaled to display part of your drawing at a particular scale (e.g. 1:67 in your example).
If you can attach your drawing file, we can help you more efficiently (see forum rules at the top in red).
crstn
Post by crstn » Fri Nov 14, 2025 3:03 pm
Thank you for answering and sorry for not attaching.
Here it is!
Floor plan.dxf
(179.28 KiB) Downloaded 204 times
Post by andrew » Fri Nov 14, 2025 3:12 pm
Your paper space had an arbitrary scale.
I've attached the drawing as I would recommend to arrange and scale it: paper space 1:1, viewport for example 1:100.
Floor plan_1_100.dxf
(181.62 KiB) Downloaded 211 times
crstn
Post by crstn » Fri Nov 14, 2025 3:17 pm
Amazing, thank you.
I don't know how I messed that up :?
