Grid Snap at 1/2 inch increments
Jim55
Post by Jim55 » Sun Nov 30, 2025 7:31 pm
Windows 64-Bit
Version: 3.32.4.0 (3.32.4)
Build Date: Sep 4 2025
Revision: d3aa6db
Qt Version: 5.13.2
Architecture: x86_64
Compiler: MSVC++ 14.0 (2015)
I am trying to set up my grid such that I can grid snap every 1/2 inch. No matter what I try, I can't get grid snap finer than 1 inch increments. Attached are screen shots from relevant Drawing Preferences tabs.
Dimension Settings
Drawing Units
Grid Settings
Re: Grid Snap at 1/2 inch increments
Post by Husky » Sun Nov 30, 2025 8:19 pm
Did you try below Unit settings "Imperial" instead of "Metric"?
Post by CVH » Mon Dec 01, 2025 4:33 am
I can't replicate your problem (3.32.4.0 Win7 32bit)
Your settings would set up a Grid with a minimal Grid size of 1/2 inch and a minimal Meta Grid of 12 inch.
Note that Grid settings other than auto are minimum values.
Zooming in, the Grid size won't drop below 1/2 inch.
Depending on an Application Preferences, the Grid/Meta Grid automatically adapts to the zoom state or are fixed.
When fixed it doesn't scale when zooming in/out, it is then always 1/2 and/or 12 inch apart.
If the minimal screen spacing is reached, it will be turned off to not clutter your entire screen.
Perhaps your current zoom state is much deeper than 1/2 inch screen-wide or much too wide for e.g. 10 pixels apart.
Is for Hatch and Linetype patterns and has no influence on the Grid/Meta Grid.
