Is there a diameter symbol?
Krischu
Post by Krischu » Thu Feb 05, 2026 7:38 pm
As the subject already asks: when applying measures to drilled holes, is there a way to apply a diameter symbol with the measure? Or do I have to draw a text with the symbol whereever it can be found?
Christoph
Re: Is there a diameter symbol?
Post by CVH » Thu Feb 05, 2026 10:48 pm
When creating a Dimension see prefix in the Option Toolbar.
When editing the label in the Option Toolbar, click right and select 'Insert Symbol'
When editing the label of a selected Dimension, click right and select 'Insert Symbol'
Note that '<>' is the placeholder for the formatted measured value in a label.
Without it is merely text.
Krischu
Post by Krischu » Fri Feb 06, 2026 10:28 am
I found this field. It appears as soon as the desired measuring method is chosen. I can choose e.g. diameter symbol from the listbox and I can also right click in the symbol field and choose a diameter symbol followed by <> or <> alone.
But it seems to have no memory. The setting disappears again and has to be renewed everytime I'm applying that kind of measure.Thanks.
Christoph
