Older drawings on latest version
MikeLa
Post by MikeLa » Fri Nov 10, 2023 7:15 pm
Windows 10 -QCAD
Now QCAD 3-28-2-0
Was QCAd 3-21-2-0
I have a couple of drawings created on an older version of QCAD
They have a lot of layers but are not particularly big - 250k ish.
They open, all be it slowly, on the older version but not on the newer version - they seem to use a great deal of RAM
I have bigger drawings with more layers (1.2M or so) that open in both versions.
Any suggestions please?
Re: Older drawings on latest version
Post by CVH » Fri Nov 10, 2023 7:54 pm
and welcome to the QCAD forum.
250k ish open slowly on the older version but not on the newer version.
The size is not a good indicator nor is the number of layers, the complexity is.
Could you share such a 'medium' size file that doesn't open on the newer QCAD releases.
If considered proprietary then you can attach the drawing to a Private Message (PM).
MikeLa
Post by MikeLa » Mon Nov 13, 2023 12:03 pm
Thank you for your response.
The "drawing" is quite complex and also contains some jpegs for "tracing" and scaling and so contains repeat images at different sizes.
I will open it in the earlier version of QCAD and split it up into several drawings and see if they work in the new version - recombining the bits I need later.
The question remains however - why would the drawing be OK(ish) in 3-21 but not in 3-28?
MikeLa
Post by andrew » Mon Nov 13, 2023 12:04 pm
Please understand that this question is impossible to answer without access to the drawing file.
