MacOS 10.15.7
QCAD PRO 3.26.1.0
The problems occur with a new blank file as well.
The drawing has the following messures: See attached file
1. If a draw a line and change to dotted line, nothing happens
2. Hatches are not working at all
See attached screenshot of file.
The testfile is attached as well.
I always updated on MacOS by overwriting the old app.
Any hints
[solved] Hatching and doted lines
- test.dwg
- (17.47 KiB) Downloaded 322 times
- Bildschirmphoto-Unbenannt 3 - QCAD 2021-04-11 11-55-16.png (136.16 KiB) Viewed 3172 times
- Bildschirmphoto-Zeichnungseinstellungen 2021-04-11 11-53-07.png (73.77 KiB) Viewed 3172 times
Re: Hatching and doted lines
1. Activate "Screen Based Linetypes" below Menu / View.
2. Try the hatch "Ansi 31", Scale 1, Angle 0. Will that work?
Thanks for the tip,
This works now.
This works now.
