Qcad pro is expired
olddude
Qcad pro is expired
Post by olddude » Sun Nov 24, 2024 11:00 pm
Hi, I bought the Pro edition over a year ago, and now I'm trying to download it on my new laptop and I can't. Is there any way to continue my set up or can I get it for free? I just use it a couple of times a year as a hobby. could you advise, please?
Thank you
Re: Qcad pro is expired
Post by Husky » Sun Nov 24, 2024 11:23 pm
sounds like you don't have a backup. Correct?
Option 1:
Renew your license sweetened with a 30% rebate (my recommendation!):
https://www.qcad.org/en/accessing-downl ... _a_License
Option 2: If you are on a Windows OS copy the Qcad Folder tree from the old Maschine and save it to the new Maschine. Then create a shortcut to qcad.exe.
Sorry, I can't help you with other OS :cry:
Note: ONLY recommended when you know what you are doing!!!
Option 3:
Qcad Community Edition is free but has less feature than the Pro Version ...
olddude
Post by olddude » Mon Nov 25, 2024 12:23 am
Thanks for the replies, I'm running qcad in Mangaro Linux, I could get the qcad root folder and copy it to the new machine, I just don't know if that would make it boot.
