Installation failed on linux mint
ste_t77
Post by ste_t77 » Tue Nov 25, 2025 3:04 pm
Good morning,
First of all, congratulations on the software.
About a month ago, I installed QCAD 3.32.4 64 bit on a PC running Linux Mint, and everything is fine.
This morning, I tried to install QCAD 3.32.4 64 bit on two different PCs with linux mint, and in both cases, I got this error (see attached image).
thank you
Stefano
WhatsApp Image 2025-11-25 at 15.01.25.jpeg (76.63 KiB) Viewed 6917 times
ste_t77
RESOLVED
Post by ste_t77 » Thu Nov 27, 2025 9:20 am
I moved the opt folder from root to home and redefined the new path in the icon properties. Now everything works perfectly.
Thank you.
