Running Mac OS High Sierra version 10.13.6
Qcad/cam version 3.27.8.0
Need directions (not the best with computers but learning) I downloaded the trail version a couple weeks ago and purchased Qcad on 1-28-23. I thought I had installed it correctly but after I save a drawing I’ve been working on and reopen it it says it’s the trail version and wants me to delete some file. How do I delete those files and will this stop from running a few minutes and telling me it closing down and I need to restart?
Thanks in advance
Mike
[solved] Trial version to purchased version
mbcarpenter
Re: Trial version to purchased version
After your purchase of QCAD/CAM, an e-mail was sent to you with a download link. Use this link to download the full version of QCAD/CAM. After downloading the full version of QCAD/CAM, you also need to install the full version of QCAD/CAM to replace the trial version.
For more details, please refer also to our web site at:
https://www.qcad.org/en/accessing-downloads-updates
Laddfarm
- Registered Member
ok i downloaded the trial version. then I bought the qcad pro and the qcad ebook i did not see the email link to use so i downloaded the off the web site now i can't get the pro version to install . when i open it still shows the trial version any help. thanks
- Husky
- Moderator/Drawing Help/Testing
Only the by download link provided QCAD version will install a Professional version. All online available download links are Trial and/or Community versions.Laddfarm wrote: ↑Fri Feb 10, 2023 1:11 amok i downloaded the trial version. then I bought the qcad pro and the qcad ebook i did not see the email link to use so i downloaded the off the web site now i can't get the pro version to install . when i open it still shows the trial version any help. thanks
To recover a lost download link please refer to this website:
https://qcad.org/en/recover-lost-download-link
Laddfarm
- Registered Member
SOLVED I figured it out forgot to download the installer
thanks for the help
