Resize circles
Use this forum to ask questions about how to do things in QCAD 2.1/2.2.
dugernaut
Resize circles
Post by dugernaut » Thu Aug 25, 2011 4:45 pm
How would I resize a circle from .086" to .089" ?
I can only enter 2 digits in the properties! Can that be fixed in a future release?
Post by andrew » Thu Aug 25, 2011 4:57 pm
Yes, that's already fixed in QCAD 3 Beta.
In QCAD 2, you can use the property dialog instead:
- Modify - Properties
- Click circle
dugernaut
Post by dugernaut » Wed Aug 31, 2011 6:24 pm
Thanks for your reply.
Would it be possible to allow circles to be entered with diameter instead of radius as a default? I'm always having to calculate radius and then enter it. That would save me a TON of time!
dugernaut
Post by dugernaut » Wed Aug 31, 2011 6:27 pm
andrew wrote:Yes, that's already fixed in QCAD 3 Beta.
- Click circle
Thanks, that works, but...
if the circle was already selected, it does not work as you state.
In other words: I've selected the circle, then I do what you suggested. Nothing happens.
Post by andrew » Wed Aug 31, 2011 6:55 pm
You don't need to select the circle, you have to click it after choosing the tool:
1. Choose menu 'Modify' - 'Properties'
2. Click the circle with the mouse somewhere near its circle line
Post by andrew » Wed Aug 31, 2011 6:57 pm
dugernaut wrote:Would it be possible to allow circles to be entered with diameter instead of radius as a default? I'm always having to calculate radius and then enter it. That would save me a TON of time!
You may want to enter the diameter in the radius field, followed by '/2', for example to draw a circle with diameter 27.25, enter '27.25/2'.
Return to “QCAD 2.1/2.2 'How Do I' Questions”
