Hi guys - if you are in need of a couple "Imperial drawing sheet templates" - here we are
Well organized imperial Drawing sheets incl. Pr-defined Layers and Blocks for:
- Paper Frame,
- Title Block incl. Projection symbol 3rd angle (US),
- Zoned Border (Sub-Block of Paper Frame),
- Logo / Name (Sub-Block of Title Block - changeable!),
Drawing unit: inch
Linear Dimensions:
Dimension height: 1/8" (0.125 inch),
Format: Fractional, Precision: 1/32"
Scale 1"=1"
Easy to configure - visible/invisible how ever you like it,
Easy to copy/scale - everything on one Layer (Drawing sheet),
The "Drawing sheet" Layer is default locked - if you have to put Data into the Title Block you have to unlock the Layer ...
Imperial drawing sheet templates:
ANSI A / 8" x 11" Portrait,
ANSI A / 8" x 11" Landscape,
Hey - how nice is that!
With the new QCAD 3.3.0 release we have more and nicer possibility's to handle i.e. the entries in a title blocks or a revision block.
It's called "Block attributes" and that was a reason for me to update the Drawing sheet templates with this new feature of QCAD.
QCAD 3 - Video Tutorial (Q&E).
"Drawing sheet template with block attributes"
Long story short:
You will find in the .zip the same Drawing sheet templates as above but now with the new block attribute function.
Hi, these are great. I would like to amend these to metric and United Kingdom standard paper sizes but I'm struggling to amend the templates successfully.
I am unable to hear the tutorial. I have logged into YouTube and still can not get the audio to play. Is this located somewhere that I could download the file?
So, then you're saying by inserting text manually in the block, not through use of the field, right? Also, I take it Standard if the font you've used for the rest of the text in the title block?
The reason I ask is that some applications have a special key sequence to insert a carriage return into a text string (spreadsheets for example) and I wanted to make sure I wasn't missing something here.
Been looking for free 2D-CAD sw as I have no longer access to MicroStation (used that about 15+ years). After seraching online, seems QCAD is a decent alternative and will give it a shot!
Now, my 1st question is, are these (or similar) drawing sheet templates available in metric units (A4-A0)?
If not, I wonder can these be "converted" to A4-Ax sizes easily? Pretty sure someone has done that already...
If I try to insert and explode these, they seem to crash my QCAD 3.25.2.0.
I'm using a Mac. I did this:
Unzipped the directory, Did QCadPro/Preferences/Widgets/LibraryBrowser, Add unzipped file path
Closed and Restarted QCAD
LibraryBrowser/ Navigated to the folder, drug the "ANSI A" into modelspace and placed it at 0,0
TX (to select the block)
XP (to explode) -- QCAD crashes out.
I tried this with ANSI E and it also crashed.
I tried again with the libraries/templates/metric/din_a3_m_landscape.dxf template from the distribution and I was able to eXPlode it into components as expected.
I was attempting to explode these ANSI templates this to see if I could access and edit the attributes, since the attributes didn't seem to show up under the entire, unexploded block.
