Library Browser Is Absent From Community Edition (3.28.1)
kennyminigun
Post by kennyminigun » Sun May 07, 2023 12:57 pm
OS: Kubuntu GNU/Linux 23.04
QCAD version: 3.28.1.0 (3.28.1)
After converting QCAD to Community Edition. I.e. deleting the following files from "plugins" directory:
./libqcadproscripts.so
./libqcadtriangulation.so
./libqcaddwg.so
./libqcadpolygon.so
./libqcadtrace.so
./libqcadpdf.so
./libqcadproj.so
./libqcadspatialindexpro.so
./libqcadshp.so
The "Library Browser" has disappeared both from Menu > View > Library Browser and from Menu > Edit > Application Preferences > Widgets.
On the recent release notes it states that 3.28.0 has "Retired SQL DB based Library Browser". Is this the intended consequence?
Re: Library Browser Is Absent From Community Edition (3.28.1)
Post by CVH » Sun May 07, 2023 5:35 pm
Yes, see changelog .. 3.28.0 (2023/03/28) .. QCAD Professional .. Add refactored and improved file system based Library Browser.
https://www.qcad.org/rsforum/viewtopic. ... 441#p40441
https://www.qcad.org/rsforum/viewtopic. ... 509#p40468
