Library Browser
Matfie
Library Browser
Post by Matfie » Sat Apr 01, 2023 8:55 am
Hello
3.28.0 (2023/03/28)
  • Library Browser
    • Retired SQL DB based Library Browser
    QCAD Professional:
    • Add refactored and improved file system based Library Browser:
do I understand that the feature of library browser is now removed from the open source version?
is there a way to insert parts?
Re: Library Browser
Post by CVH » Sat Apr 01, 2023 10:17 am
Yes I think so ...
Yes, menu File .. Import or simply drag and drop from any OS file viewer list.
Matfie
Re: Library Browser
Post by Matfie » Wed Apr 05, 2023 9:02 pm
inserting a dxf seems to work, but the involute gear generator I wrote does disappointingly seem out of reach now
Re: Library Browser
Post by andrew » Wed Apr 05, 2023 9:10 pm
Matfie: Try dragging the JS file into the drawing area. That should work as the library browser does exactly the same.
Re: Library Browser
Post by Husky » Wed Apr 05, 2023 10:12 pm
@Matfie
You could also consider to stick a while with QCAD CE 3.27.9 ...
Matfie
Re: Library Browser
Post by Matfie » Thu Apr 06, 2023 9:24 am
andrew, thanks for the response but I think "dragging the file" is something that requires a desktop environment/file manager to provide some external functionality? I'm a bit old-school and only use a window manager. What does this action do, can I do this from the QCAD console or the ECMAScript Shell ?
Re: Library Browser
Post by andrew » Thu Apr 06, 2023 11:03 am
OK, that's not a scenario that is supported. You'd need a file manager with drag and drop support, such as "Nautilus" ("Files").
You can have a look at the action that inserts a script item at:
https://github.com/qcad/qcad/blob/maste ... iptItem.js
And how it is called at:
https://github.com/qcad/qcad/blob/maste ... tWidget.js
-> EventHandler.prototype.drop
Yes, should be doable (see above).
