Need help! I cannot change the color of the yellow blocks
alicia
Post by alicia » Tue Oct 31, 2023 5:58 pm
Hi all, I am a beginner to cad drawing and I just cannot finger out how to change the yellow color blocks to black or other dark color :(
the yellow color is so bright and not visible when print out :shock:
Thanks a lot if you can help me!
st sanitary updated.dwg
(2.23 MiB) Downloaded 143 times
st plumbing updated.dwg
(2.23 MiB) Downloaded 145 times
Re: Need help! I cannot change the color of the yellow blocks
Post by andrew » Tue Oct 31, 2023 6:42 pm
Unfortunately, the color of these entities has been set to "yellow" (as a fixed color) rather than being defined by layer as is recommended.
This means that what normally would take a few clicks would now be a major effort: You'd have to change all these blocks manually.
Perhaps, you can resort to printing in black / white of greyscale instead:
Edit > Drawing Preferences > Printing > Colors > Black / White or Grayscale
Post by CVH » Tue Oct 31, 2023 11:37 pm
Had some success with Misc .. Modify .. Set Attributes by Layer (QCAD Pro)
What also may fix the usage of Lineweight 0.00mm. :wink:
Return to “Chat”
