Windows 11
QCAD professional 3.28.2.0
Why is it that the true type font "TXT" renders differently in QCAD professional 3.28.2.0 than the windows fonts preview? see 1.dxf, screen shot and txt font in windows fonts.pdf.
In most cases QCAD is exactly the same as the true type font.
Font rendering
Font rendering
- 1.dxf
- (185.38 KiB) Downloaded 158 times
- screen shot.png (78.05 KiB) Viewed 3497 times
- txt font in windows fonts.pdf
- (92.84 KiB) Downloaded 145 times
Re: Font rendering
TXT.TTF is rendered as Standard.cxf in QCAD.
A file saved under QCAD with a text in TXT reloads as Standard as did your example file on download.
CXF is a QCAD native format: https://www.ribbonsoft.com/en/tutorial- ... -cxf-fonts
TXT origin is TXT.shx what is an ACAD shapefile. See: https://www.qcad.org/rsforum/viewtopic. ... SHX#p36530
