Just downloaded Version 3.29.0
Using Win 11
Now have annoying partially obscuring floating hatch pattern covering pointer position.
Thanks for previous problem solution regarding rulers.
André (Montreal, Canada)
annoying hatch pattern covering pointer position
Re: annoying hatch pattern covering pointer position
I hope this isn't your cursor being malformed.
Are you using system cursors or not?
See menu Edit .. Application Preferences .. Graphics View .. Appearance .. Cursor
You can always try to reset your configuration:
https://qcad.org/en/tutorial-resetting- ... figuration
Remind that this will reset all your QCAD customization's and tool options.
I can not find references about your previous problem, this is your first posting under user 'Andrepr'.
Win 11
Ver 3.29.0
Wasn't using system cursors... Changed and seems fine now.
Thanks for yo ur help.
André
Ver 3.29.0
André
This should not be an issue.
It is more a general preference in the nature of "I like to use my system cursors"
Something has changed recently:
https://github.com/qcad/qcad/commit/614 ... 50054d450d
Maybe reporting it as a bug on Bugtracker is in order.
Filed a report: https://qcad.org/bugtracker/index.php?d ... sk_id=2517
