I just purchased QCAD Pro after using the free trial for a few hours. I completely deleted the trial version and installed the Pro Version, but some tools still locked out, just like trial version had. Please help.
Thanks!!
QCAD Pro Not Installing on iMac
Re: QCAD Pro Not Installing on iMac
Note that some menus (tools) require a selection (for example Modify > Move / Copy, Modify > Rotate, Edit > Copy, etc.).
Please refer also to the user manual of these tools:
https://qcad.org/doc/qcad/latest/reference/en/
If you cannot solve the problem, please indicate which tool(s) exactly you are referring to.
Fixed by re-installing again. ?? Thanks !!
