QCAD crashes on file save
lloydster
Post by lloydster » Wed Jan 28, 2026 5:43 am
MY OLD VERSION OF QCAD PROFESSIONAL STARTED CRASHING ON FILE SAVE
I HAVE PURCHASED AND DOWNLOADED A NEW VERSION OF QCAP PRO AND INSTALLED IT AND STILL CRASHES ON FILE SAVE OR SAVE AS.
64 BIT SYSTEM ON MSI INSTALL
HAVE BEEN USING THE SYSTEM FOR 4 YEARS NOW WITH NO ISSUES
PLEASE ADVISE OF ANYTHING I CAN DO
I HAVE ATTACHED SOME SCREEN SHOTS OF WHAT HAPPENS AND THE FILES TESTED ON
stamfords template 2801.dxf
(31.66 KiB) Downloaded 2 times
SWAN EVO profile.dxf
(557.77 KiB) Downloaded 2 times
Screenshot 2026-01-28 153711.jpg (230.2 KiB) Viewed 74 times
Screenshot 2026-01-28 153642.jpg (229.03 KiB) Viewed 74 times
Screenshot 2026-01-28 153423.jpg (174.73 KiB) Viewed 74 times
Re: QCAD CRASHES ON FILE SAVE
Post by CVH » Wed Jan 28, 2026 6:39 am
More a topic for the QCAD Troubleshooting and Problems forum. :wink:
All in upper case is considered as shouting online.
  • "It is not proper netiquette to TYPE IN ALL CAPS!"
Your drawings and files look sane.
The 'Save As' dialog shows us that you are saving to the 'Windows' folder on drive C:
Isn't that a folder inside the protected area guarded by the Windows UAC?
You will need Admin rights to write there.
It is already a better idea to store user data files in newly created user folders.
Not advisable but you could attempt to start QCAD with Admin rights.
