Convert Spline / Polyline with bulges
tukuyomi
Post by tukuyomi » Tue Sep 13, 2016 7:40 pm
Hello !
Qcad has tools to explode Splines in straight segments, but not in arcs.
Is anyone familiar with an algorithm to convert spline to Arcs --with a bit of tolerance, of course?
Thanks
Re: Convert Spline / Polyline with bulges
Post by Husky » Tue Sep 13, 2016 8:45 pm
tukuyomi wrote:Qcad has tools to explode Splines in straight segments, but not in arcs.
Explode a Spline = Polyline,
Explode a Polyline = Lines and Arcs - whenever possible,
tukuyomi
Post by tukuyomi » Wed Sep 14, 2016 9:12 am
Am I missing some settings here ?
Please consider the attached drawing. If I explode the splines here, I only get straight segments.
Even if I select minimal values in App Preferences > Modify > Explode, I still get too much straight segments, meaning too much G01 gcode to write to my old Laser cutting machine.
What I would like is the possibility to explode Splines as Lines and Arcs --as Ellipses do--, with some kind of tolerance.
By the way, the function that draws those Splines is a Sine function.
I'm trying to write with a script based --not on splines this time, but-- on Polylines with bulges values, but those are tricky to find/calculate :p
test0.dxf
(101.62 KiB) Downloaded 936 times
Post by andrew » Wed Sep 14, 2016 9:35 am
tukuyomi: Please indicate what version of QCAD you are using, thanks.
tukuyomi
Post by tukuyomi » Wed Sep 14, 2016 10:15 am
Oops I updated to 3.15.5, and indeed, Splines are exploded to polylines and arcs ! Thanks !
I increased the Spline Tolerance in the Apps Preferences, but I still get too much entities ; weird, using the drawing I posted above, on the bottom spline, there are far more arcs toward the left.
Is it possible to increase the tolerance more ? I tried to put a big value (10 and even 100), but it did not have effect on the exploded spline.
Post by andrew » Wed Sep 14, 2016 11:16 am
